Results 1 to 4 of 4
Hybrid View
    Nov 2009
    18
    Default Trailblazer 325/ 12RC wire feeder issue
    Hey hoping someone may be able to help, I have a 12RC wirefeeder hooked up to a 325 Trailblazer (350 hours), running .045 Blueshield T9 flux core with C25 gas, 28.5 volts (at the machine, 50' 1/0 cables and 50' 14 pin miller remote cable) about 380 IPM. The issue is, when the machine is at low idle (2420rpm on the display) and I initiate the arc, it sputters, then i have to wait for it to idle up before my arc is stable. This didn't happen for the first two days, and since I am fitting on this job, tacking becomes annoying. I have spoken with miller, and on my days off I am taking it in to get it load tested and check the fuel delivery. I have switched the machine from CV Flux core to CV solid wire and have yielded better results. How ever I can not get it to initiate a stable are from low idle. I have hooked my wire feeder up to an XMT 350 using my cables and it runs just like a 22A wire feeder does. Is there something I am missing? This is my first time running wire off a engine drive but I expected better.
    Also since my machine will be going in to service, does anyone know if I can hook up a 12RC to a Lincoln 305g?(my backup machine)
    Oct 2004
    Edmonton, Alberta
    8,351
    Engine fuel modulator is likely to blame for the sputtering.
    Nov 2009
    18
    Well its at the doctor today, so hopefully its something simple. I am picking up a Trailblazet 302 for the meantime cause I cannot run that suitcase off a Lincoln.
    Nov 2009
    western mass
    213
    I guess in a bind you could run the xmt 350 off the Lincoln and run the feeder off the xmt.
