Thread: CST 280 - Tig
    Default CST 280 - Tig
    I have a CST 280 and I use it for stick welding. I have a Miller mig welder that I use for light sheet medal. I want to use my CST 280 for tig welding. What torch and accessories do I need to buy? I have never tig welded.
    Illinois
    626
    Sep 2009
    Canada
    189
    Does the CST 280 have a gas solenoid in it? If it does, you dont need a tig torch with a gas valve on it. If there is no gas control solenoid in the CST 280, you need a tig torch with a gas valve on it.
    Other then that, tig welding will be very easy with the CST 280. It is a lift start dc tig welder and will do a very good job. Tig welding stainless pipe would be sweet with this machine.
    Miller Bluestar 2E
    Thermal Dynamics Cutmaster 52
    Torchmate CNC table
    Ironworker Welder
    Operating engineer
    Illinois
    626
    No gas solenoid valve on CST 280. Require gas valve torch.
    Here's the CST 280 manual, see page 18 for tig
    http://www.millerwelds.com/om/o217655e_mil.pdf
