Results 1 to 8 of 8
    Jul 2009
    New York New York
    46
    Default material for a pull up bar
    needed to make a pull up bar, what material do I needed to use?
    about 5ft in length needed to hold 200LB without flexing or bending
    black pipe ?
    or those chrome moly tubes4030/4040 ?
    just wanted to made one not buy one from a sporting goods store.
    Apr 2011
    365
    Default It depends...
    ...where are you hanging it?
    I would use pipe and threaded fittings screwed to a doorway, tight.
    Of course I have no hopes of even pulling ONE up.
    Just For Home Projects.
    Jul 2009
    New York New York
    46
    it's a doorway walkway leading to my living room 5feet wide.... the not sure if 1 inch black pipes will be strong enough for that wide stretch. just needed expert opinions. Thanks for the reply.
    3,928
    1" black pipe in sch 80 would work...Bob
    Apr 2011
    365
    Quote Originally Posted by dogdog View Post
    That is why I said THREADED ends. I thought you would figure out to lag them to a studs. Five feet is a long way and the "tension" on the pipe by "pulling" it to the jamb would add to the "system."
    Aug 2012
    Hermiston Oregon
    265
    Why 5ft.
    wouldn't 3ft be more than enough. For a pull up bar
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Apr 2011
    365
    Quote Originally Posted by eecervantes83 View Post
    Why 5ft.
    He is clearly trying to span an existing wall opening...
    Apr 2010
    278
    You could add vertical brackets to the ceiling, say a foot in from each side. That would give you an effective 3 foot span. Put a decorative panel or something in the middle that swings/lifts away when you want to do chin-ups. Make it look like part of the decor.
