Results 1 to 10 of 12
    Default wat lpm fir shielding gas welding titanium?
    haven't figured how to attach pics yet, but about to undergo first titanium welds. got chamber built, jus need to purchase gloves and rings to seal gloves to chamber. all thats left is finding flow rate of shielding gas and steady hand for the execution. looking forward to input and ill post again thru out process
    Oct 2009
    306
    I think you mean CFH but anyways. I used to turn my chamber purge on at around 10 CFH and my torch set to 15 CFH, try it on a test piece first and make sure you have no oxidation of the weld or HAZ (heat affected zone). If you have any oxidation bump up your chamber CFH a bit. What size gas cup are you running?
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Nov 2003
    3,721
    A good place for the gloves and rings is TP Tools...
    http://www.tptools.com/Sandblasting-Gloves.html
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    size 12
    i watched a video on weld tube for gas lense and cup info
    Oct 2009
    306
    Yup nice big cup with a lense in the chamber, you should be good.
    thanx for term correction, and input
    Los Angeles
    2,957
    Quote Originally Posted by jrscgsr View Post
    It is the same thing but in metric
    L/PM Litres Per Minute
    A litre is a Volume measurement already
    CFH- Cubic Feet per Hour
    a foot is not a volume so we have to then state it as a Cube to show volume.
    Most likely your regulator gauge has both measurements on the dial- at least all of the ones I have do.
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    Default Oooops...
    A cubic foot IS a measurement of volume.
    i had to look up acronym foe the cfh, wher i com from its known as lpm. i stil glad to kno mor. lil knowledge nun hurt nunbody
