Results 11 to 15 of 15
    Default Miller auto dark helmet
    I will try the prong fix in the morning and hope it works temporarily so I can find the Panasonic batteries.
    402
    Quote Originally Posted by Texas113 View Post
    cool, let me know if it worked... i did that to mine probably 3 years ago, and its been fine since
    SyncrowaveŽ 200
    Lincoln AC/DC 225/125
    402
    did you try prying the prongs down ?
    SyncrowaveŽ 200
    Fabman it worked. I cleaned them with alcohol and a swab then bent the prongs a little. I also shimmed the battery in their little trays for a snug fit. Since I did that not one problem whatsoever. I forgot how convenient they are. Thank you very much for the help.
    402
    cool man, glad it worked for you.... later
    SyncrowaveŽ 200
Warning: Function split() is deprecated in /mnt/stor3-wc1-dfw1/357822/357839/www.millerwelds.com/web/content/lib/footer.inc.php on line 83
