Results 1 to 10 of 12
    Default which electrode for welding titanium?
    bout to begin first titanium welds, ordered filler rod at 63.oo a lb. wats best electrode fir job ?
    Aug 2012
    Hermiston Oregon
    286
    From previous post. I've read your unsure of your base metal why would you go out and spent money yet. Have you done any test.. titanium isn't magnetic.
    If grind on it puts out bright white sparks.
    Unlike mild steel which are yellowish.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    i appreciate ur input, its out of necessity. nor for fun
    Aug 2004
    Milan Michigan
    1,834
    Well then, Fur those welds I use 1/4" since it for ( Necessity )
    Nov 2003
    3,626
    Smile Best Practices Titanium TIG
    Quote Originally Posted by thatsallid0 View Post
    Since you are diving into the pool headlong without any previous Titanium TIG experience... maybe you will find these articles helpful in giving you some of the basics...
    Titanium 101: Best TIG (GTA) Welding Practices
    http://www.millerwelds.com/resources...anium-welding/
    and
    http://www.millerwelds.com/resources...ium-tube-pipe/
    Maybe shine a little light on the subject..
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Dec 2010
    Sutton, MA
    38
    I use 2% lanthanated, but any electrode suitable for DCEN is fine.
    Filled by Zanconato Custom Cycles, on Flickr
    thanx to all
    Nov 2006
    407
    Quote Originally Posted by zank View Post
    thats a nice consistent bead width.... how does titanium filler flow ? like steel or like aluminum ?
    Syncrowave® 200
    Lincoln AC/DC 225/125
    Lincoln Weld Pak 100 wire feed
    Dec 2010
    Sutton, MA
    38
    Flows very nice. And the puddle is bright and shiny. It's a lot like welding stainless. The one thing I find challenging if I'm not 100% focused is that the tip of the filler rod can get stuck on the base metal on the leading edge of the puddle or if it touches anywhere else on the base metal. I try to be very deliberate with my dabs and I try to feed closer to the center of the puddle. The tip of the filler seems to stay molten and will freeze off on whatever it touches that isn't molten.
    I also pay very close attention to torch angle and shielding as I am coming up to an outside corner or moving around a tube. The weldment shape can block the shielding ahead of the puddle if you don't anticipate it. It's pretty agonizing when things all of a sudden go blue and purple around a corner because of torch angle.
    Nov 2006
    407
    thanks so much for your input
    Syncrowave® 200
