Results 11 to 17 of 17
    Nov 2003
    3,565
    Question
    Machine polarity settings??
    DCEN
    Electrode Negative for Flux Core Wire ??
    Input power, 120 or 240vac ???
    NO Extension cords??
    Have you consulted the settings chart in section 5-3 of the manual for fluxcore wire??
    http://www.millerwelds.com/om/o239988j_mil.pdf
    Again... I would urge you to practice on scrap FIRST..
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Puerto Rico
    26
    I set the volts around 6 and 7 and wire speed to 50 and yes it is DCEN. I do have to use a 50fts extension cord 0f super service 10/3 240v.
    Puerto Rico
    26
    The piece does get realy hot, but I dont see a constat pudle.
    Puerto Rico
    26
    The roll is a .035 308l fco made by htp
    Nov 2003
    3,565
    Header design & fabrication at best is a complicated, difficult process....
    Making a turbo header is an order of magnitude more ambitious an undertaking...
    Here is a great source of information and supplies.. Stainless Headers Mfg
    http://www.stainlessheaders.com/index.aspx
    Their fabrication videos are truly outstanding.. and FREE...
    http://www.stainlessheaders.com/headerfabrication
    My Blue Stuff:
    Puerto Rico
    26
    Thanks a lot!
    Nov 2003
    3,565
    Turbo headers are especially prone to failure due to expansion and contraction stresses brought on by extreme heating and cooling cycles they are exposed to... elevated pressure ant temps that can be extreme in a turbo environment.... cracking and joint failure can happen VERY quickly...
    this happens even with "Big Name" factory installations....
    just ask any Porsche 951 Turbo owner...
    Careful design and the incorporation of slip joints will help to insure longer life and service... here is a good example..
    http://www.stainlessheaders.com/ecotec_header
    Here are a bunch of close up pics showing construction details..
    http://www.cobaltss.net/forums/2-0l-...market-267479/
    as far as using MIG for this project?? I personall use TIG for this type of work...
    but there is no reason that a careful, skilled MIG operator could not achieve decent results..
    My Blue Stuff:
