Results 1 to 10 of 17
    Puerto Rico
    26
    Default ss custom turbo header
    Hi, I'm a newbe on welding but I'm making a turbo header for my bike. It's going to be made on SS 304. I will like to received advice, sugestions and maybe alittle help about tric etc. I'm using a .035 ss fluxcore at 240v on my 211mvp. I need to know what can I use in order to clean the metal.
    acetone
    dont forget to purge ss pipes
    Puerto Rico
    26
    Like I said, I'm new on this, what do you mean with purge?
    CT.
    333
    If you are using flux core I don't think you are going to purge with argon.
    Miller Dynasty 300DX
    HTP MIG 240
    HTP 380 Plasma
    Bridgeport Milling Machine
    South Bend Lathe
    Etc. Etc....
    tjsperformance.com
    I would recommend using solid wire with gas mix, and acetone or similar well make for easy clean up.
    Puerto Rico
    26
    Ok, thanks for the advice, but I only have this .035 ss fluxcore roll. I can't buy a 3mix bottle on this moment. But thanks! Does any one knows about about what kind of setting I should use? The volts/wire feed combination for that wire?
    Nov 2003
    3,830
    Quote Originally Posted by Goliad316 View Post
    You will be doing yourself a HUGE favor by getting a bunch of spare tubing and do a lot of practicing on it... Only when you are confident in your fitting and welding skills should you attempt to start the real project...
    No shame in developing your skills to equal the task...
    Think you will be much happier in the long run..
    How can anybody advise settings if we do not know the thickness of the tube and flanges as well as the maker and formulation of fluxcore??
    For an example: Aufhauser Flux Cored Stainless Steel Wires
    http://www.brazing.com/products/Weld...red_stainless/
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Puerto Rico
    26
    Hi the tube is a 304 sch10, the flanges are 3/8". other is 5/16" and a t3 flang of about 1/5"
    Puerto Rico
    26
    I allready start the proyect but I'm seen a lot of splaters on the area, and I'm worried of not getting good penetration.
