    May 2013
    24
    Default Orientation of Tungsten Using Grinding Wheel
    Hi,
    This is the same information that I wrote in a previous thread; but, it may have been too deep in the thread. So, I hope it's okay to post again.
    I haven't had much time to get setup to dive into TIG.
    I recently purchased two new wheels for a spare bench grinder that I have in the garage that will only be used for tungsten grinding. (One is 80 grit, the other 120.)
    I hope the answer to this question isn't too obvious....
    I understand the need to basically grind along the axis of the tungsten. I just can't visualize the best way to do this with the guard assembly on the bench grinder.
    It's my understanding that I should use the side of the wheel. Is this correct? How about the orientation.... toward the direction of travel, or away from it?
    For others who use a bench top grinder, do you leave the guards in place?
    Maybe it's something that will become clear once I attempt a couple. Sometimes a little advice goes a long way.
    Jeff
    Houston, TX
    900
    Use the face of a dedicated wheel, with the tip of the tungsten facing the wheel just like you would sharpen a chisel. Harbor Freight makes an inexpensive 3" grinder that is perfect for tungsten.
    Dec 2012
    Simcoe Ontario
    98
    What works the best that I've seen is a belt sander that is turning away from you. And always keep moving the tungsten side to side so you don't wear grooves in the belt / grinding wheel. Also never grind on the side of a bench grinder wheel. It's a good way to wear the sides and eventually the face will fly apart. As for the bench grinder gaurd you can lower it and tilt it so you can get a good angle with the tungsten. And uh use a drill makes nice uniform sides and clamps the tungsten well and keeps your fingers away. Good luck
    Chucking up your tungsten in a cordless drill & grinding length ways in the center of the wheel is the old tried & true redneck method.
    Miller Trailblazer's ( 2 )...MillerBobcat 250...Millermatic 251's ( 2 )...Miller Syncrowave 200...Miller Syncrowave 180SD...Miller 12VS Suitcases ( 2 )... Hobart Hefty CC/CV Suitcases ( 2 )...Miller 30A Spool Guns ( 2 )...Miller WC 15A Control boxes ( 2 )...Thermo Dynamics Cutmaster 50 Plasma Cutters ( 2 )...Thermo Arc Hi Freq Units ( 2 )...Smith / Victor O/A Sets...DeWalt Power Tools...Craftsman / Snap On Hand Tools... Two Dodge Mobile Rigs
