Results 1 to 10 of 10
    Default welding stock exhaust on my o8 r1
    lookin for some help.. to save my money, decided to remove baffles and insulation from dual stock exhausts on my o8 r1. edge prep all done, went to fit up and weld. to my surprise, it aint aluminum, stainless, or mild steel. that i can tell. help plz if able to identify base metals.
    Nov 2012
    Northern Arizona
    526
    Should be titanium. Good luck.
    MillerMatic 251
    Maxstar 150 STH
    Cutmaster 42
    Victor Journeyman OA
    Aug 2012
    Hermiston Oregon
    265
    Pictures please
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    May 2013
    East Tenn
    148
    Think Elvis is right. I remember my FMF pipe was titanium. That means DC TIG. X2 on the good luck.
    Default that makes sense
    thanx
    Default in addition to welding stock exhaust on my o8 r1
    do i need to purge cans wit argon when i begin the welds ? ordered titanium filler rods at 63.oo a lb. might be better off just buyin an m4 exhaust
    Aug 2004
    Milan Michigan
    1,774
    Quit wasting money on more HP unless your a drag racer, If your a knee dragger then you want to put your money into brake pads, suspension, learn how to adjust your suspension and good tires.
    My 98 R-1 had more power than I could use when at a small track like Gratton, At Mid- Ohio I could have used a few more ponies.
    At Road America then yes I could have used more.
    My best money spent however was tuning the suspension and grippy tires.
    9
    For the best quality weld on titanium you really want to build some type of chamber to protect the weld from any air. Good luck, post some pics
    Nov 2003
    3,327
    Quote Originally Posted by Envychops View Post
    I believe he has built a purge cabinet of some sort...
    BUT he has split this subject into multiple threads....
    makes it much tougher to follow...
    here is the other..
    http://www.millerwelds.com/resources...lding-titanium
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    NY
    99
    Default R1 exhaust
    I just did exactly what your attempting for a customer and dam it never took one picture. The problem with the welding is the exhaust is stainless and titanium. Thats why its riveted and spot welded together. I cut back the ends to get rid of the rivet holes and tig brazed the edge seams with silicon bronze after gutting the exhaust. Then riveted the end caps and trim moldings back on. I also had to cut the end exhaust tube back a 1/2in because it stuck out of the end cap to far. All in all the job was a time consuming chore. Cool down time in between welding was a killer but major critical. Short runs only. Good luck!
