Results 11 to 18 of 18
Thread: spoolmatic 30a
    I don't know about the smoke....
    but is the positive lead ran through the wc115? It has a current sensor that when current is detected, it switches from run in speed to set speed on the gun (wire feed speed).
    Does your have a contactor?
    Mine did not, so I bought one that had a 24v coil and installed it myself, the bobcat has to be in run for my contactor to close when I squeeze the trigger.
    Oct 2012
    kannapolis,nc
    32
    Quote Originally Posted by Amc724 View Post
    yes the pos lead runs through the wc115, through the contactor. the issue is with the 115v power for the drive rolls. it runs fine off shop power but not off the bobcat. It did run fine, but the wires got hot and fried the ground wire when run off the bobcat
    Nov 2011
    164
    Default spoolmatic 30a
    The information you want is already existing on this website, click the links above. Start clicking and researching yourself.
    Nov 2003
    3,721
    I would first ask if you have gone through ALL the troubleshooting steps in this reply??
    AND the troubleshooting section of the Bobcat manual??
    http://www.millerwelds.com/resources...597#post309597
    If you have gone through all of it and still have erratic 120vac output...
    you might have a problem with your Bobcat..
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Oct 2012
    kannapolis,nc
    32
    yes, I have checked all that I can. Nothing in the trouble shooting refers to the problem I am having, That is why I am having the outlets checked before I go any further
    Nov 2003
    3,721
    Quote Originally Posted by kbenz View Post
    Not True
    Check Section 9-2. Auxiliary Power Troubleshooting Page 33 of the manual
    http://www.millerwelds.com/om/o405e_mil.pdf
    My Blue Stuff:
    Oct 2012
    kannapolis,nc
    32
    That's why I have Jeff coming out to check my outputs. until then I do not know if my problem is the outputs or not. It may have just been a wire rubbed raw and shorted out (I hope)
    thanks
    Oct 2012
    kannapolis,nc
    32
    got back to it again. outlets checked out fine. Replaced the 120v power cord that fried with a 14g cord to the wc-115a. ran some wire. all seemed ok. thanks for the input
