Results 1 to 10 of 18
Thread: spoolmatic 30a
    Oct 2012
    kannapolis,nc
    32
    Default spoolmatic 30a
    running my spoolmatic off my bobcat for first time today. ran good off my shop 110 (for wc-115a) but when I try to run the 110 off the bobcat it don't want to weld? feeds ok. doesn't seem to have enough current to weld though. (yes I have my fine tune amps turned up on bobcat) Any ideas? do I just need to turn up my amps?
    Nov 2003
    3,690
    Quote Originally Posted by kbenz View Post
    Do you have it set to CV constant voltage mode??
    for MIG you will want CV mode NOT CC mode
    and adjust your VOLTS not your amps...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Oct 2012
    kannapolis,nc
    32
    Yes I have it switched. Everything works fine when 115 is plugged into my shop. Problem is when I plug the 115 into the bobcat
    Nov 2003
    3,690
    Smile
    Could you post the serial number of your Bobcat 225G so we could consult the correct version manual... ??
    so we can make sure there are no switches in the wrong position..
    lots of times it is just a simple switchology mixup..
    My Blue Stuff:
    Oct 2012
    kannapolis,nc
    32
    Kk117340
    Nov 2003
    3,690
    Is the Engine set to "RUN".... so it runs full speed??
    NOT to "Run/Idle" where it will idle down
    and that CB3 & CB4 are not tripped
    See page #19 Fig 6-1
    http://www.millerwelds.com/om/o405e_mil.pdf
    My Blue Stuff:
    Oct 2012
    kannapolis,nc
    32
    yes, it is set to run. I will download and check that out. thank you
    Nov 2003
    3,690
    You might also check 9-2. Auxiliary Power Troubleshooting Pg #33
    No output at auxiliary power
    Reset circuit breakers (see Section 6-1 or 6-2).
    receptacles.
    Press optional GFCI receptacle Reset button (see Section 6-2).
    Check fuse F1 and replace if open (see Section 7-4 or 8-6).
    Check plug PLG6 connection
    My Blue Stuff:
    Oct 2012
    kannapolis,nc
    32
    Default crap........
    Finally got back to it. I must have had something set wrong before. It ran great for a couple beads off the bobcat. Then the rpms dropped for a split second and everything went to crap. looked over and seen smoke(wc-115a). unplugged, shut it all down. pulled the cover off the wc-115a and the ground wire coming in is burnt. what ya think?
    Oct 2012
    kannapolis,nc
    32
    Rewired the 115v . Plugged it into my shop power. Ran fine. Cord never even got warm. Got a friend comin over tomorrow to check outputs on bobcat
