Thread: Dialarc hf
    Default Dialarc hf
    DIALARC HF with water cooler ... can I tig aluminum with this machine and if so how thick? Also, can I use my 12vs suitcase with this machine? Thanks :-)
    Nov 2003
    3,324
    Thumbs up
    Quote Originally Posted by The Tractor Doctor View Post
    Yes you can do aluminum...
    For thickness figure 1 amp per thousandth of an inch without preheat... about 1/4 inch it being a 250 amp machine... thicker with some preheat..
    Yes you can use a 12VS... being voltage sensing you can use it with a drooper like the dialarc...
    here is the manual for the Dialarc HF
    http://www.millerwelds.com/om/o315u_mil.pdf
    and for the 12vs
    http://www.millerwelds.com/om/o1500_8l_mil.pdf
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Thanks for the quick reply H80N!!! So by drooper, I'm guessing the machine sucks, lol. I'm getting the dialarc for $500. I already own a few suitcases. ...
    Nov 2003
    3,324
    NOooooo.... no suck... Dialarc HF is a decent machine..
    Drooper refers to the type of power supply... (typically TIG and Stick)
    it characteristicly will have a higher open circuit voltage that will "Droop" to a lower voltage under load... that is a CC constant current supply..
    nothing the matter with that model machine
    as it turns out that style of supply needs a voltage sensing wire feeder to lay a decent bead with wire...
    and you have one in the 12vs... so you are in luck..
    a typical MIG supply is CV constant voltage...
    My Blue Stuff:
    Thank you very much for the info
