Results 11 to 16 of 16
    8,228
    Electricians generally don't solder. nor do they know circuit board components. Need an Electronics guy.
    I have a buddy at work that works in the radio shop and works on and fixes motorola radios. I couldn't find the part # for the Q11 but through several hours of searching on the net I believe I found the part # for the PC1 control board. Is miller part # 204807, the PC1 board for the millermatic 210 and is it a plug and play item.
    8,228
    You have to look at the physical part Q11, get the number off it, then venture over to NTE.com and get a cross reference for it. Because your not into electronics, I didn't suggest it. Of course your NOT going to find that part listed ANYWHERE on the Miller site.
    Anywhoooo, merely order the board from:www.miller4less.com
    Well I talked to a miller tech today in Appleton WI and he give me a simple test to try which pointed straight to the control board as the problem. He confirmed the miller part #204807. It is ordered and I should be back in business soon. It was that easy.
    8,228
    Yes, we/I knew it was the control board, that was obvuious, However if you happened to know someone like an electronics guy, that Q11 is about $1.50
    That would have been way cheaper than a board. I will source out the Q11 part and have the electronics guy at work change it and at least I will have a spare board. How do I find Q11 on the board, will it be labeled.
