Results 1 to 6 of 6
Hybrid View
    Aug 2004
    Milan Michigan
    1,836
    Default Inerpac 100 Ton ram with electic hydraulic unit.
    I just scored a gently used 100 ton hollow bore ram ( Hydraulic cylinder with a hole through the center ) , I also got a 40 ton Hollow bore also, Both cylinders are approx. 12" long.
    I also bought a electric over hydraulic unit made by inner pac also.
    What I will use it for is pulling hard to remove pins out of equipment, putting bushings into equipment buckets.
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    WOW, those are some nice rams. That 100 ton ram is a monster. I had a 60 ton for a while, but had an extremely hard time using it by myself for pushing / pulling bushins and pins. It was way too heavy for me by myself. I eventually went doun to a 30 ton. It worked great for me . Good luck with that monster 100.
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    Apr 2006
    TAXACHUSSETTS
    1,504
    I just battled a 1-1/2" x 16" pin out of a 6 whl international with a high rail setup for riding the tracks.I used a 30 ton ram and a hand pump.But it would not budge.Until I had at it with my arc-air slice torch and a few rods took the center out of the pin about 10" deep then it came out.I would have took some pics but my camera walked about 2 months ago still not sure if I lost it or someone stole it.
    BB402D
    TB300D
    DIMENSION652
    MM250X
    MAXSTAR140
    S-32 FEEDER W/1260 IRONMATE FC/GUN
    HT/PWR-MAX1250 PLASMA
    Aug 2004
    Milan Michigan
    1,836
    Jspence, your right the 100 ton is a big boy, I think I saw the specs on it weighing 109 lbs.
    I have 6 cranes in the shop and one on the truck without them it would be a little more difficult.
    Back in the winter my cousin who does portable line boring came to my shop and used his 100 ton Hollo bore to install a bushing in a 5 yd, excavator bucket that was .002 over size, 100 tons plus the shock of a sledge hammer put it in and no welding was required to hold it in place.
    After I saw that I just had to have one.
    With the price of factory pins being close to $ 600.00 it sure is nice if you can save one once in a while, Not to mention eating all the blow back when trying to carve out a pin.
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    I definitely know what you mean about eating the blow back from a pin. All of my line boring is done in the field and unfortunately I don't have a small crane to use. That was why I switched to the 30 ton hollow ram. Much easier to handle and luckily I haven't had a problem with it pushing and pulling.
    JIM
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Aug 2004
    Milan Michigan
    1,836
    Now I'm thinking I should look for a used portable line boring machine, But if I get that I will then need a lathe to spin up bushings.
    Just how many things do I need to get into.
