    Default Strength of equipment
    How does this rack stay strong enough to hold up to 500kg loads with all the holes? I would have thought it would weaken a structure.
    Add Content
    Dec 2011
    436
    I don't think 500kg is that much for that structure depending of course on the guage of the tubing and how far you drop the 500kg load onto it. That said each tube is essentially 4 angles with the extreme edge of their legs re-inforced by the interconnection to to the adjacent angles. If you partially collapse any of the tubes then it is a whole other ball game. Take a look at adjustable pallet racking. It holds 1000s of kgs and is also punched full of slots.---Meltedmetal
    Oct 2009
    Reno, NV
    299
    The vast majority of the load is compression, so I'd say that is how it does it. If, for example, one end of the rack was securely attached to the wall, with it cantilevered out (no support bracing) and the weight placed out near the end away from the wall, the weight bearing capacity would be hugely less than when the load is compression as it is in the picture. Kind of like how you can sit on the end of a pretty skinny rod with a seat on the end of it as long as it is pointed straight up, but if you put one end of the same rod in the vise and push down on the other end, you can easily bend it.
    A lot of what can be supported by any structure depends upon the material, but the direction of the forces involved and if the loads are compression, torque, bending, or whatever is also VERY important in how the structure is designed and what sort of loads it can bear.
    Don J
    Reno, NV
    Unreal information. Thanks again, I was having doubts about building something similar. But I'll bang it out now.
    PA
    372
    Here is an example we have all seen.and perhaps used ourselves.
    As Don pointed out, the loads are mostly vertical in both cases.
    However all it takes is a bit of side load or a weak side member and the frame could collapse.
    4 empty soda cans will support a person's weight if they are undamaged but if there is a dent in one, look out.
