Results 1 to 10 of 11
    Aug 2008
    saskatchewan
    33
    Default plasma torch field use
    How does a plasma torch behave with a compressed bottle of oxygen for supplied air?
    Apr 2012
    Queen Creek AZ
    38
    Not to sure on O2 for field plasma might not be the best idea.
    But i can speak on nitrogen use and compressed air from a portable gas air compressor on my trailer. Both work great i use nitrogen every once in a while when i need it away from my trailers 100' reach of air hose.
    Hope this helps
    Take care
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    Compressed Air is the most commonly used gas for lower current plasma cutting and works well for most metals from gauge thickness to 1 inch. It leaves an oxidized cut surface. Compressed air can also be used for plasma gouging on carbon steel.
    Nitrogen is often used for higher current plasma systems and for cutting materials up to 3 inches thick. It produces excellent quality cuts on most materials.
    Oxygen is used when the highest quality mechanized cuts are desired on carbon steel up to 1 -1/4 inch thick. The cut face is smooth, and dross is easy to remove. Oxygen can also be used on stainless steel and aluminum, but it produces a rougher cut face.
    Argon-Hydrogen Mixtures are generally used for cutting stainless steel and aluminum. They produce a clean, high quality cut face. Argon-Hydrogen is required for mechanized cutting of any material more than 3 inches thick. This mixture also provides an excellent gas for plasma gouging on all materials
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    Apr 2012
    Queen Creek AZ
    38
    Jpence- awesome right up , i did not know that i was thinking O2 would be bad for the plasma cutter being a flammable gas. Possibly damage torch and not cool it properly.
    I have used nitrogen on thin guage up to 1/2" it works great no issues i was using a nitro tank before i had my compressor.
    Im using a powermax 45 hypertherm
    Learn something new everyday.
    Take care
    8,231
    Nitrogen would be my choice, way cheaper, Higher pressure so it lasts the longest.
    Aug 2004
    Milan Michigan
    1,811
    Jspense, I also have to say thanks for that info.
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    Glad to be able to help.
    I know for me it made a big difference when using the right gas for the right application. I am also going to have to agree with cruizer about the nitrogen. Usually the best all around way to go.
    JIM
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Jun 2012
    24
    Only use oxygen in plasma systems that are designed for oxygen. Most small portable plasma systems are designed to use compressed air...the use of pure oxygen in these systems can cause internal combustion that can damage or destroy your plasma torch, leads and power supply Oxygen is not flammable, but certainly supports combustion.
    You can get high pressure cylinders of compressed air, regulate the output to about 90 to 120 psi and use it with an air plasma system. Compressed nitrogen will also work in most air plasmas, but will not cut as well as air.
    Jim Colt Hypertherm
    Quote Originally Posted by Azphiks View Post
    Dec 2011
    424
    Some dive shops will fill air bottles if the hydrostatic and visual tests are up to date.---Meltedmetal
    Nov 2009
    western mass
    208
    hey jim colt. good to see you here. I read all your stuff on plasmaspider.
