    407
    Default square weld joint symbol
    guys,
    i have a weld symbol cheat sheet at work, but it dont have this weld symbol im about to describe.
    it a usual square weld joint symbol, with the two vertical lines, but also has horizontal lines above and below those vertical lines..
    hopefully you can understand my description, i have searched the internet for hours and cant find it. also i have ordered a new symbol chart but wont be here for a week or so.
    thanks guys
    SyncrowaveŽ 200
    Lincoln AC/DC 225/125
    Maybe a plug weld of some kind. Is it possible to talk to the engineer? I've had issues on jobs were the engineer was drawing symbols under his own interpretation
    Oct 2009
    306
    If I'm not mistaken that is usually the joints required profile when shown above the weld symbol. Also sometimes will have G for grind flush ect.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    407
    thanks guys, i will check into it and let you know what i find
    SyncrowaveŽ 200
    Feb 2013
    Canada
    112
    The two vertical line are usually a butt weld with a space or gap in beetwween,is there a number in there??
    The two horizontal line meen finish weld,flat weld , flush with plates!
    Can you take a pictures?
    407
    yes, found out it's a butt weld. they want to part welded on the sides also, the butt weld. two flat plates laying on top of each other...
    thanks much guys
    SyncrowaveŽ 200
