Results 1 to 10 of 12
Hybrid View
    Sep 2009
    South Carolina
    571
    Default Can heat treating stop rust
    I am making a trailer coupler lock guard to prevent bolt cutters from getting at the lock.
    I don't want to paint it because it will just get scratched off.
    Is there a good heat treating method that will keep it from rusting?
    It will be made from regular carbon steel.
    northern NJ
    1,890
    Galvanize, powder coat, paint it & repaint as needed or make it from stainless.
    MM250
    RCCS-14
    Apr 2010
    284
    Quote Originally Posted by Hardrock40 View Post
    ... Is there a good heat treating method that will keep it from rusting? ...
    No.
    Quote Originally Posted by USMCPOP View Post
    No.
    That's kinda funny but true nontheless. Do your research on heat treating, specially mild steel and you'll be a lot smarter cat. Hopefully.
    Roll on bed liner is about as good a cheap, anti scratch coating as you'll find. Follow all directions, do the right prep, and it'll last pretty well thru abuse and abrasion. You can apply it with a roller, a brush or a tooth brush on small parts.
    Heat treat isn't your friend here, you can lern that easy with a few clicks of the old mouse.
    You really need to educate yourself if you are planning to sell a product. The marketplace will eat the unprepared alive : )
    J
    Some days you eat the bear. And some days the bear eats you.
    Oct 2005
    North Central Indiana
    782
    I'm no expert but I would guess hard chrome would be about the best as far as coatings go.
    http://www.hardchromeplating.net/ind...es/hard-chrome
    Sep 2009
    South Carolina
    571
    well I did do a little research before I asked. Just skimming some sites about it. Found some things about heating then spraying with some type of oil then repeating several times.
    Also seasoning a cast iron skillet comes to mind but that's probably for a different purpose.
    Thought well wth, I'll just ask the pro's.
    Guess I should have made it clear this is just a one time thing, not a product for sell.
    Just for my use. Its tight inside and any coating would prevent movement and scratch off.
    Stainless would be great, didn't have any. Guess I'll just lightly paint it.
    I am just making it hard for punks to remove from the truck. The receiver is pin locked and welded to the hitch, the ball is welded, the coupler nut on bottom will be welded and this guard will stop a bolt cutter.
    The lock is a 5 pin, harder to pick, made from Baron steel also. So it will take a cut off wheel, time and noise to remove the trailer from the truck.
    Thanks for the quick reply's, come back tomorrow and I'll try and take a couple pics.
    Apr 2010
    284
    ... Found some things about heating then spraying with some type of oil then repeating several times...
    You are probably referring to coating it with boiled linseed oil and then heating it until the oil dries/polymerizes. Sort of a poor man's powder coat.
    You might try spraying it with Zinc Cold Galvanizing or a similar primer.
    Just for my use.
    Well that makes it a lot easier, no flood of warrantee work.
    You can try several things till you're happy.
    J
    Mar 2012
    Brookshire, Texas
    21
    What you are referring too is called bluing and is most commonly used on firearms as a corrosion and heat resistant finish, again it is not a coating it is a finish, there are plenty of YouTube videos that explain how to do the process
    Sep 2009
    South Carolina
    571
    Thanks for the pointers, in the end its just a guard so opened the inside a bit and painted it.
    I like it, couldn't find a good lock set up in the stores around here. The locks was on a clearance rack in Lowes, 2 pack for 11 bucks.
    Now for that cheap side door lock, a person could pry that thing open with a sturdy pocket knife. But not for long.
