Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. #21
    Cave Creek Az
    1,036
    For forge building it is likely best to go on iforgeiron.com and search there. I do quite a bit of metal work for the highland games here in Phoenix. What is it that you are making exactly?
  2. #22
    Default Need to make steel rings
    Just making this
  3. #23
    Add Content
  4. #24
    Dec 2011
    406
    Quoits?
  5. #25
    Upstate SC
    143
    That looks like less than 1" diameter stock.
    CG
    Old Miller Swinger 180 Buzzbox
    Miller Diversion 165
    1945 Craftsman Atlas Lathe
    Smithy Lathe/Mill
  6. #26
    Yes 1 inch/25mm
  7. #27
    3,927
    Have them cut from 1" thick steel pipe and round over with 36 grit sanding discs. Prob 20 minutes each...Bob
  8. #28
    Cave Creek Az
    1,036
    If you are building the handles then I think you are way off base with 1". Ours are all made with 1/2" round bar. To make them easily out of half inch you can weld an end to a pie e of 6" pipe, then heat with a torch and start bending, then just follow it around. Keep it spiraling up until you have as many loops as you will need. Then slice through the whole mess with a cut off wheel. Bend the ends together and weld. I just bent some solid 3/4" square into half circles today, and while it is doable, it takes a lot of heat. Much easier is to find a local blacksmith and have him do it, not a big job.
  9. #29
    That's all great advice, I will use every method described off here that I can. I will probably use 20mm as I have a lot of it left over from fixing gate hinges. Ill stick up s pic of my efforts!!!
