Results 11 to 20 of 29
    Jul 2010
    Salem, NJ
    291
    I would either sub it or burn them from plate
    1,914
    Question to the op.
    How many do you need to make/buy? What exactly is the use?
    turbo38t Guest
    Default Need to make steel rings
    @turbo they're a bit pricy at 21
    @mmw initially 10 for Highland games, but if I get the bending right I've railing to make up so plenty of bending to be doing 180's though not 360's bends.
    turbo38t Guest
    Theee are cheaper brands.....gotta figure time, material and gas as well. Good luck. Dave
    Quote Originally Posted by Bossman2000 View Post
    Ah ok Dave ill give it a proper read later.
    Hi, how would Make a forge? Any pics?
    Oct 2009
    306
    You can buy a cheap ring roller. Just make sure it's up to your capacity.
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    Dec 2012
    Simcoe Ontario
    104
    Just get a propane tiger torch heat them and bend them around something the same diameter. If you have a pipe the right diameter weld the one end to it and just keep bending it around like a spring till you have enough coils. Then cut them pound them flat and weld them together. Multiple same size rings.
