Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    Default Need to make steel rings
    Hi would this machine be able to bend a 25 mm/ 1 inch bar into a 360? If anyone has and recommendations I'd appreciate. I don't have any heat (propane). I'm trying to avoid renting.
    not near you
    148
    With that bender you may have to make the rings in halves and weld them together...Good luck
    Upstate SC
    143
    1" steel bar, no heat, and that radius? I think you are in trouble.
    CG
    Old Miller Swinger 180 Buzzbox
    Miller Diversion 165
    1945 Craftsman Atlas Lathe
    Smithy Lathe/Mill
    1,897
    No it won't. That is a tubing bender & you are asking about bar. Big difference.
    Could it be done with heat and that bender? I've been on to a gas supplier and now you can buy the propane canister/cylinder. So I will have heat.
    Bayweld I never even though of welding the two halls together, genius!!
    2,927
    Quote Originally Posted by Bossman2000 View Post
    No
    Round Tube Capacity 7/8"
    Wall Thickness .047"
    Square Tube Capacity 1"
    3,948
    Burn em from 1" steel plate and do a round over to suit...Bob
    2,927
    How many do you need to make?
    this might work for you
    http://www.westechrigging.com/riggin...are-rings.html
    Cave Creek Az
    1,048
    You can heat bar stock in a forge and bend them around a piece of tube with no problems. Forge is easy to make.
