Results 1 to 8 of 8
    Jan 2013
    Ohio
    57
    Default Lincwelder AC-180-T
    Just bought a Lincwelder AC-180-T from a co-worker for 20.00 anyone know where to fine parts for it?....said it worked the last time he used it but don't know when that was...I figured it was work 20.00 even if I have to scrap it...the stinger could be replaced plus the plug could be updated....not sure if I can find the lugs for the stinger
    Jan 2013
    Ohio
    57
    Default photos
    Photos of lugs stinger and plug
    Apr 2010
    284
    That thing probably dates to 1950 +/-. You'll have to clean up the lead plugs or make new ones. My 1952 AC180C has a stove plug on the input like yours.
    226
    Have you looked on Lincoln welder site for the op manual and parts manual they are free.
    Jan 2013
    Ohio
    57
    Does yours run good still?
    Jan 2013
    Ohio
    57
    Not yet was on there website for alittle bit...didn't really investigate to much...kpack
    8,101
    The plug is obviously a 30 amp 230, the stinger, you can get anywhere, and the weld pins cross over to a Miller. If you took it to a LWS they could point you in the right direction
    Jan 2013
    Ohio
    57
    Thanks Cruzier
