Results 1 to 8 of 8
Thread: 300 shop master
    Mar 2012
    Southwestern Ontario
    44
    Default 300 shop master
    Looking at purchasing a 300 shopmaster for another machine to replace my 250 miller, looking into it because I'm shopping for a tig/arc welder and if works out the mig option would save me some space, is it possible to put a 10 and 14 pin connector on it to run my wirefeeder and also spool gun?
    8,172
    Quote Originally Posted by rustymfg@hotmail.com View Post
    There is a 14 pin on it to run a S-22A feeder. or WC-24 to run your Spoolgun. For Tig your still going to need a HF box
    Mar 2012
    44
    Ok sounds good thanks , I have purchased a wc24 controller for my trailblazer already so I would be set for that, I'm new to tig I would only require a HF box for aluminum correct?
    8,172
    Thats correct, as your Alumium weld will wonder everywere, also the HF box is handy for starts on steel as well.
    Mar 2012
    44
    Ok thanks for the tips, would I be wiser to spend a little more cash and get a xmt instead? Or are there any downfalls going that route? My main thing is I don't have alot of space and anything smaller which will do the equivalent or better job I would rather go that way thanks
    8,172
    The Shop master is a great do everything machine. I get one in and its gone the next day.
    Jul 2011
    Huntington, NY
    118
    ​an XMT won't do aluminum. No AC output. Also no HF.
    Jun 2011
    New Milford ct
    75
    Default Shopmaster 300
    I have one with a suitcase feeder, spool gun and HF-15 box. Been a good machine and welds nice. Would love a square wave machine for TIG welding aluminum, however not made of money. With the HF unit it does aluminum good, most of what I do is thin so the sine wave works ok. I do mostly SS with the TIG and this machine does that very good. I did good on the purchase price so Im happy
