Thread: Mp 30e
    Default Mp 30e
    Can I run a 12vs suitcase off a MP30E?
    8,099
    Yes, BUT you have to jumper the 115 VAC contactor with something so you can put the neutral and hot leads across from your 115 outlet into the 2 wire contactor. Contactor turns on then weld away. The MP30E units are fine machines.
    Ok...but I have a 12vs...NOT a 12rc...so I don't need a remote outlet. Will it still work?
    8,099
    Quote Originally Posted by The Tractor Doctor View Post
    I new that, but if I recollect the 30E, doesn't have a way to turn the contactor on, no contactor on no weldy weldy, ya get it?
    Default Ok, here's another....
    DIALARC HF with water cooler ... can I tig aluminum with this machine and if so how thick? Also, can I use my 12vs suitcase with this machine? Thanks :-)
