Results 1 to 10 of 18
    Oct 2005
    North Central Indiana
    782
    Default black pipe airlines and the crud that develops in them
    Black pipe airlines and the crud that develops in them.
    Seems aluminum piping the air compressor companies are offering is the way to go these days if you are building a new shop or thinking about redoing your airlines. The picture shows a line that was only a few years old. Granted the picture probably depicts a worse case scenario but the science is real. At least a 1/2" air hose strung along a shops' wall on an angle with a filter and water separator on the end won't develop rust and hold moisture. Copper corrodes, stainless has carbon in it that could react to acids over time.
    aluminum airline http://www.quincycompressor.com/our-...6#.UcHhB_m1F8E
    Illinois
    612
    How long was that in service ? We demoed out a auto shop with 20 bays in it and at least one drop to hose reel minimum to each. Shop was in service over 20
    years and all pipe was in great shape. Actually brought some home and made gates for farmer.
    That may have been poor install. I never saw anything that bad. That looks more like a steam condensate return line inside.
    Oct 2005
    782
    I believe the compressor website said a few years.
    http://us.kaeser.com/Products_and_So...iping/pipe.asp
    Last edited by tackit; 06-19-2013 at 11:01 PM. Reason: correction on length of time to a few years not two years
    WY...armpit of U.S.A.
    659
    No kidding? Huh, wonder how many folk out there think through the advertising and see a vendor that says his product is better than sliced bread and all alternatives are junk? Its on the Internet so its gotta a true, right?
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
    Mar 2012
    13
    You need to run with an air dryer in order to limit the internal corrosion on the air lines.
    Oct 2005
    782
    Quote Originally Posted by WyoRoy View Post
    I agree with you to a point, but it seems aluminum would have it's advantages over BP. Technology always advances, it never stays the same. I would use it over BP if I was redoing a shop's airlines or building a new one.
    Wa
    600
    I and all my friends use copper. My friend has had his wood shop on copper for 25+ with zero problems.
    Oct 2005
    782
    I would imagine climate, shop conditions, hours of use and if moisture and water equipment was properly installed on the lines has a lot to do with it. I wouldn't have that much to put up so cost against copper or SS I don't think would be much of a factor. I like the way it connects, with some planning I could easily have mine up in couple hours.
    Jan 2008
    13
    The only problem with the aluminum is it's mucho dinero from what Ive seen
    Jason
    Millermatic 135XP
    ThunderboltXL 225/150 AC/DC
    Millermatic 252
    Oct 2005
    782
    I don't need a lot of aluminum piping to do my shop, if I go 10 feet from the compressor make a drop and install a water separator, filter, valve and clean out I'm set ...so I do think cost would be a big concern.
