Results 1 to 10 of 14
    May 2013
    10
    Default Purging mig c25 shielding gas after welding?
    I saw on a tutorial that you should purge the c25 gas out of the line when your finished welding. Seems like a waste of gas.. but is this a true statement, can't seem to find an answer on the net.
    Thanks!
    Aug 2012
    Hermiston Oregon
    271
    I have never done that. My lines don't leak. Plus I sometimes leave my bottles open. Through lunch break.
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
    Apr 2012
    Western Pa.
    291
    My bottles are on all day long & many days I'm in shop 16 hrs. Also many shops run 2 shifts bottles open 24 hrs. What good would it be to purge out gas out. Never heard of that.
    If my pressure bleeds off over weekend or after vacation etc. I purge the line before start first weld.
    Not everything u read is true or I'd be a French Model. My wife assures me that's not true.
    Nov 2011
    159
    I personally do purge when done.
    Turn wire speed way down, turn bottle off and pull the trigger.
    Way back in high school my shop teacher (welder for 20+ years) thought us to purge for the following reasons.
    1. Better for solenoid/o-rings as they are not under constant pressure .
    2. Makes you purge the line every time before welding (granted your mig doesn't self purge)
    3. Assures your bottle won't be empty next time you go to use it.
    I have always done this since my teacher showed me way back.
    May not make sense for high use applications as I am a hobby type user and not a pro welder
    Oct 2009
    Reno, NV
    299
    As a matter of habit from WWAAAYY BACK, I always release the pressure on my MIG and TIG machines as I never really know when it will be used next. The "common wisdom" is that letting the pressure off is best for all the parts that would otherwise be holding pressure and it sure as **** can't hurt anything. Besides, if letting out 1.5 cents of gas once in a while is going to cause a guy to be eating cat food anytime soon just maybe the money is getting away a LOT faster elsewhere, huh?
    Don J
    Reno, NV
    Houston, TX
    900
    If it has a regulator or flow meter, I purge after use.
    Apr 2010
    284
    I used to burp my children.
    Nov 2011
    159
    USMCPOP;
    I don't understand!
    Apr 2010
    284
    Quote Originally Posted by ericher69 View Post
    USMCPOP;
    I don't understand!
    Kidding - feed a baby, burp it afterwards.
    Oct 2005
    North Central Indiana
    782
    I always bleed the gas and open the wire drive so before starting to weld again the gun can be purged without wasting wire. It would be a nice feature if they would put a purge button on the gun..... that way after stopping for what ever reason you could re-purge the gun right at the handle without having to open the machine and wire drive up. It would stop sputtering and porosity on starts.
