Results 1 to 2 of 2
    Default 350 LX High freq cuts out
    Hey gang. Have a 350LX and the high frequency cuts out after about 20 minutes of use. I pulled the side panel to observe the points and the arc is strong and constant then it just cuts off and if you touch the chassis you get a shock.
    Anyone have experience with this?
    Feb 2013
    Southwestern WV
    95
    Look close at the wiring. I found a wire that had layed on top of a screw and had shorted to the chassis. I just repaired the wire and all was good.
    Syncrowave 350lx
    XMT 350 CC/CV
    S74DX Feeder
    30a spoolgun
    Hypertherm 1000 g3
    Harris O/A
    Cincinnati lathe
    Acer Ultima "Bridgeport Mill"
    340hp Quincy and 400 gallon of air
    Other doodads and a stoker coal stove
