Results 11 to 12 of 12
    Jun 2006
    Abernathy, Tx
    54
    Default 350 P mig welder
    Either your wire speed is to low or the voltage is to high. I have had the same problem and its wire speed or voltage needs some tweaking
    Aug 2012
    Hermiston Oregon
    266
    Quote Originally Posted by hunter59:308876
    Quote Originally Posted by BearM View Post
    The 350p is the easiest machine to work with, IMO. Flip the flap on the front and read. Set all the settings and you can pull up a chair and kick back.
    Thanks for responding.........I did just that but it does not want to start, it pushes back and spits terrible and it won't laydown a nice bead when it finally does start
    Sound like your wire speed is to high compared to your heat setting
    What are your setting at the moment
    Miller Bobcat 225NT onan
    Millermatic 211
    Spoolmate 100
    Miller 130xp
    2. 4-1/2" grinders
    1. 9" grinder
    14" Makita chop saw
    1/2" Aircat impact gun 900#
