Results 1 to 10 of 16
    May 2013
    10
    Default Sealing Steel Welds on Stainless Steel art projects...
    What would you use to 'seal' steel welds on stainless steel so that it slows or stops them from rusting? I am using steel wire on my stainless steel art projects.. I have noticed it takes no time at all for the welds to show rust and I want to slow or stop it with a sealer of some type.. any suggestions? (can't afford stainless wire just yet)....
    http://www.flickr.com/photos/2319618...n/photostream/
    Apr 2009
    Upstate SC
    143
    Steel wire?? Why aren't you using SS wire?
    CG
    Old Miller Swinger 180 Buzzbox
    Miller Diversion 165
    1945 Craftsman Atlas Lathe
    Smithy Lathe/Mill
    May 2013
    10
    Quote Originally Posted by chewinggum View Post
    CG
    Nope.. I just started out about a month ago and I just had steel wire for the mig.. stainless was alot of money for me to invest in when I didn't know if I would like or even be good at what I am doing.
    I had talked to a few ppl that said the steel wire would be ok, but that I should seal to help them from rusting so quickly..
    northern NJ
    1,910
    To answer your question you'll need to prep the surface by scuffing & cleaning. Then apply a clearcoat or paint.
    But you should be using stainless wire & tri mix gas unless you want rust or discoloration.
    MM250
    RCCS-14
    May 2013
    10
    Crud.... I have argon/co2 mix, I would have to switch that out too??? ****..
    northern NJ
    1,910
    Argon/co2 will work but it is not the right gas & again you will be losing some corrosion resistance.
    MM250
    RCCS-14
    May 2013
    10
    oh well.. it is garden art after all.. rust will probably enhance the look..
    Feb 2012
    Wa
    633
    Spray with deft or other clear lacquer. After paint prep of course.
    alabama
    750
    I bought a roll of stainless wire from Airgas which is formulated to use with 75/25(so they say).Have not tried it yet.
    2, XMT's 350 cc/cv
    1, BOBCAT 250
    1, TRAILBLAZER 302
    1, MILLER DVI
    1, PASSPORT PLUS
    1, DYNASTY 200 DX
    1, MAXSTAR 150 STL
    1, HOBART CHAMP
    1, HF-251 BOX
    1, S-74d
    1, S-75DXA
    2, 12-RC SUITCASES
    2, 30 A spoolguns
    Oct 2012
    yuba city, CA
    59
    Default Airgas SS wire formulated for 75/25?
    Quote Originally Posted by fabricator View Post
    Please give us the name/designation of this wire, since
    this assertion by Airgas flies in the face of the metallurgy/chemistry
    of SS welding with high CO2 content gas.
    I'm not bashing-you, I'm very curious to know more particulars about
    this claim.
    From my own experience-this wouldn't be the first time that Airgas has touted things that just ain't-so.
