    May 2008
    Troy, MI
    377
    Default Deck Repair of Lawn Tractor
    This week's project was to fix the mower deck for lawn tractor for my friend's church. The problem was the welds that attached the brackets to the mower deck were broken and you could wiggle the brackets relative to the mower deck. After we cleaned it up you could see that the mower deck had lots of spider web cracks, which resulted in the brackets being attached to very little structural metal. The root cause was likely to be the deck getting hung up on stationary objects.
    We repaired the tractor on Saturday, the normal mowing day. I machined a shoulder nut to replace the missing shoulder bolt so that we could get it back in service for Sunday. It would be a pain to mow the large church lawn with the push mowers.
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    May 2008
    Troy, MI
    377
    The rest of the pictures
    Miller Thunderbolt
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    Jul 2009
    Australia
    1,031
    Great repair
    Ji
    Grip it and Rip it
    Dec 2012
    Front Royal, Va
    64
    Real nice.
