Results 1 to 10 of 12
    Oct 2005
    North Central Indiana
    782
    Default Cope got the 1/4" CDI
    Couldn't help myself, the cute little bugger will fill the gap, it goes from 30-150 inch lbs. It has the same quality feel to it as the others.
    Houston, TX
    884
    Good for you. Nearly thirty years ago, I bought that same wrench from my Snap On dealer. It had a 3/8" head, and I had him swap out fore 1/4". I don't know how many times I have adjusted the bands on a Torqueflite transmission using 72" #, but I have done my share. I just noticed the quick release, nice.
    I still have your 3/8" in my watch list. One day....
    Feb 2011
    The GREAT State of Texas!
    158
    The last tool I bought from the Snap On guy was the red handled 1/4 ratchet, about 8" long. Didn't ask the price before I said I wanted it...nearly died when I went to sign the ticket - $98.00! Too embarrassed to say no way!
    Roger Troue
    Retired since 2004
    Miller 211
    Miller 200 Syncro
    Miller 375 Extreme
    Oct 2005
    782
    Quote Originally Posted by cope View Post
    I sure am glad you advised me to check out CDI torque wrenches, I couldn't be more satisfied. I'm going to keep em in the house because of the extreme differences in temp around here.
    The 3/8 is what I used to torque the welding table's legs to the floor, it just feels good in your hands... I'll keep an eye out, if I come across a good deal on a 3/8 I'll let you know.
    I have to remove the aluminum side covers on the Snapper's Zero Turn's gear boxes and check the grease in them this summer, it's been about three years since I had to replace gears and repack the transmissions with new grease......the grease dries out from the heat and cakes up then it stops lubricating/cooling the gears, the mighty 1/4" will finalize putting things back together.
    Stay cool buddy...
    Oct 2005
    782
    Here's what a mower transmission looks like after the grease has dried out and caked and the damage it causes.
    Oct 2005
    782
    Quote Originally Posted by TxDarth View Post
    I know, but if you figure the years of service you are going to get from it and the pleasure of working with good tools it's not a bad deal.
    Houston, TX
    884
    Tackit, I got out my 1/4", 3/8" and 1/2" Snap On wrenches and assured them that although I was looking at a CDI 3/8", they weren't being replaced.
    Oct 2005
    782
    Cope, what's the new 3/8 going to be for, different inch pounds?
    I don't think they can make CDI wrenches any better, maybe they could gold plate some for gifts or awards.
    Houston, TX
    884
    Quote Originally Posted by tackit View Post
    No, foot pounds. It goes from 5-75 foot pounds, and mine is 15-100. I don't really need it, but when it comes to tools, need means nothing.
    Dec 2012
    Front Royal, Va
    64
    I would put a few ounces of gear oil in the gear case and use synthetic wheel bearing grease. That will fix the problem with the gears getting dry. Just saying......
