Results 1 to 8 of 8
    Apr 2013
    7
    Default Vertical Welding SMAW
    Wondering if anyone knows any good manipulation techniques for 6010 groove welds in vertical uphand, 3/8 to 1/2" weld size.
    Whip and pause... It's a fast freeze rod
    Apr 2013
    7
    I am asking for weave techniques for 3/8 to 1/2" welds i understand it is fast freeze
    Oct 2005
    North Central Indiana
    783
    I'm assuming the root and hot passes are already in. I don't think I ever weaved 6010 on those size welds in the vertical with 1/8 6010 rod. I just jump from side to side hesitating on the sides long enough to wash in and let the metal settle in the middle by itself. You are only suppose to weld 3X the diameter of the rod technically.
    Why would you weave it? There are other rods for that what's the project
    Oct 2009
    306
    My manipulation technique is to put down the 6010 and pull some 7018 from the oven
    and wp2025 weldcraft torch
    Miller 125c plasma cutter
    May 2013
    East Tenn
    148
    Apr 2013
    7
    Haha, unfortunately I have to weave 6010 for class... i guess 5/32 rod might fill better, i would weave 7018 if it was up to me. Atm it is open corner 3g 1/2" plate, 1' long. for the test there is two fit ups, one is 6010 root and 7018 hot,fill and cap, and the other is all 6010. must be nick tested at 3,6,9 on both weldments
Tags for this Thread
