Results 11 to 17 of 17
    Aug 2004
    Milan Michigan
    1,834
    MMW, I totally understand, You did what the customer asked of you, The only thing I usually do different is to run my wear bars past the outside edge of the bucket to protect the corners and always make sure the leading edge of the bucket is wider than the back to prevent it from sticking, I'm sure you know that but wanted to remind others reading this post.
    Nice job.
    The customer is always right and this way you will get to rebuild the bucket a little sooner than normal, Its a win win for you.
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    Default How about this one
    This was one of the hurry up and get it done as cheap as possible. Is a 54".
    JIM
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    Default While were at it.
    This was another one. Was much smaller, but still.....
    JIM
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    1,914
    What kind of material will it be digging in? I ask cause I always put the wear bars on going side to side instead of front to back.
    Looks good but wow were they beat up.
    393
    looks great to me.
    Feb 2010
    YOUNGSTOWN, OHIO
    172
    Like I said earlier, they wanted it done asap so I had to go with what I had in stock. The bottom plate was an A36 5/16" and the wear bars were A36 1/2" x 6".
    I installed the bars vertical because the customer wanted it like the OEM bars. What do they say "The customer is always right". It was a "general purpose" bucket. Thay used it for everything from digging dirt to pulling and smashing concrete, as you could see.
    I didn't mind though. Kept me busy.
    JIM
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Lodi, CA
    1,307
    I've been doing buckets for years now, never once have I put wear bars going from side to side. Yes, they are easier to put on and replace, the manufacturers love it (side to side), but the operators and contractors hate it, especially if they want a "clean trench" for laying pipes into. If you are just digging a hole, doesn't matter, but a couple miles of trench, you will see the difference. I use 1044/1045 steel, formed cold, have a special bender for this, if you heat them first you completely destroy the wear properties. Looking at Jpence's pictures, oftentimes I will put a short piece in-between the main wearstrips, right at the heel of the bucket. Also, like Portable mentioned, I will hang the outsides out a quarter or half inch all the way around, this protects the edges and the sides.
