Results 1 to 2 of 2
    Nov 2012
    Granville, ohio
    14
    Default AEAD Wiring help?
    Does anyone have a diagram or info on which lead plugs into which terminal on the idle control board? I have the owners manual but nowhere have I seen where the terminals go. Thanks guys
    Aug 2008
    Orange, TX
    1,216
    Need a unit SN. Too many AEADs to guess which one you've got.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
Tags for this Thread
