Results 1 to 4 of 4
    May 2013
    East Tenn
    148
    Default Lincoln Superglaze 4047
    Has anyone used Lincoln's 4047 aluminum wire? Suppose to increase silicon , minimize hot crack and higher shear strength than 4043. Just wondered if it could be possibly used in a 211w spoolgun since it can't run 5356 well.
    Aug 2010
    Los Angeles
    1,165
    Quote Originally Posted by Precision View Post
    Who told you that the 211 can't run 5356, and why? If anything, 5356 feeds smoother and burns hotter than 4043 due to the magnesium.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    Dec 2011
    388
    Quote Originally Posted by shovelon View Post
    The good folks at Miller did. Refer to the lastest specs on the machine and post #25 in this thread http://www.millerwelds.com/resources...2C+5356%2C4043
    I don't say it can't be done but I think I read somewhere else that 5356 needs more current than the 211 can continuously deliver.----Meltedmetal
    Aug 2010
    Los Angeles
    1,165
    Quote Originally Posted by Meltedmetal View Post
    Perhaps it is this article. http://www.millerwelds.com/resources...cess-at-Home-/
    I don't know when the article was written, but it it does burn hotter and faster, so more skill is involved. The article does recommend the use of 5356 for a stronger weld and corrosion resistance, and I can tell you that you would want to use 5356 for a better anodize color match. Personally I only use 5356, so experience does help.
    Miller Dynasty700DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MKCobraMig260
    Lincoln SP-170T
    Hypertherm 1250
    Hypertherm 800
    2 ea. Bridgeport
    LeBlond 15" Lathe
