    Default How to Remove the Backing Plate?
    Haven't done this yet but curious, how does one remove the backing plate when practicing for a test using single-V-groove, open root? Looks to me like the backing plate is solidly welded to the two work pieces.
    Miller 211 MVP
    Hobart StickMate LX 235
    Lincoln AC 225
    CutMaster 42
    Jul 2008
    Flin Flon & Creighton area
    233
    air arc it off or torch it off , and lots off practice. leave a very thin amount and grind off the rest. Im assuming this is for test plate coupons? We even used to chuck the coupon up in the milling machine and shave them off too.
    I have a welding addiction
    Sep 2009
    Canada
    192
    Some places (with a machine shop) will use a milling machine and mill it off but most of the time it is just washed off with a cutting torch or arc air.
    We wash ours off with a torch. Removing the backing strip is not part of the test but be careful not to take off too much and ruin your test piece.
    You want the backing strip solidly welded and fused to the work piece. If it is not, you won't pass the bend tests.
    Miller Bluestar 2E
    Thermal Dynamics Cutmaster 52
    Torchmate CNC table
    Ironworker Welder
    Operating engineer
    Apr 2008
    254
    At school we were using a portable bandsaw which was fast.
    Hampton, Va.
    386
    Carbon Arc.
    Wheelchair
    Nov 2009
    western mass
    208
    ive just washed them off with a torch.
    Sep 2012
    seaford de
    406
    Quote Originally Posted by HayFarmer:308709
    Same here.. since their usually cut up in pieces you can cut off the excess material and trim it so you can fit it in the portaband. Ive never seen a shop use a torch on them before bend testing.
    Dec 2009
    722
    I've always gauged them off, nice and easy. But you have to be good at gauging.
    Lodi, CA
    1,305
    Quote Originally Posted by Thrutraffic View Post
    Just out of curiosity, what is a backing plate doing on an OPEN ROOT weld??????
