Results 1 to 10 of 13
Thread: mig problem
Hybrid View
    May 2013
    8
    Default mig problem
    OK, I'm new to welding, doing some plug welds on test pieces, there going good, but as soon as I move over to the car I'm working on, I can't run a bead. It just pops and leaves little balls og weld. Its the same thickness. What I've got to do first is when I pulled the radiator support out, I pulled a little chunk of sheetmetal with it from the piece it was attached to. So I'm trying to weld in a little piece in to fill the space. Now, this is the inner fenderwell and upright assembly, its doublewall, but the whole is only missing from the top piece I'm trying to fix, ant ideas?
    Los Angeles
    2,967
    Do you have a clean area for the Ground Clamp?
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    May 2013
    8
    yes, I even put a c-clamp over the gr clamp. Its an 04' mustang. I don't think they'd have a corrosion protection over that metal that you can't weld though.
    Dec 2011
    444
    To echo Ed"s question, did you grind the area clean where you are connecting your ground? And how far from where you are welding did you make this connection?---Meltedmetal
    May 2013
    8
    ok, I just tried the same weld again, but on test pieces, and I put teck screws through the two pieces im welding together into the rad. support. area under the two pieces was cleaned to metal with wire brush down to metal and cleaned under ground clamp. just clamped a piece of number 4solid copper wire to the pieces and put my welder gr clamp to that and still same results. If turn up higher it burns the meal away, but only the top pieces I'm trying to attach
    Oct 2007
    Cave Creek Az
    1,096
    Is the paint all cleaned off the area? Are you sure it is steel (check with a magnet)? Is the car outside?Try to bump up the gas flow when you move out to the car, or shield the area from drafts.
    Mar 2012
    Brookshire, Texas
    21
    Set your machine to the thicker material and keep the center of the puddle on it, only hittingthe thinner material with the edge of the puddle so you don't burn thru it, if you are properly grounded and your metal is clean then you shouldn't have a problem
    Oct 2005
    North Central Indiana
    783
    Make sure when you cut your wire off with your pliers you always make 90 degree cuts, a pointed wire will cause bad starts. Is it possible the double wall is interfering with gas reaching the weld? any fans blowing on you?
    May 2013
    8
    inside with no breeze. nothing blocking the gas. cut wire at 90deg. On the butt welds, yes, I was starting in the middle thinking to let the puddle ooz on over and melt into the thinner metal, and I've had some luck with the plug welds. But the second type of weld I'm trying to do I guess is called butt welds, they're killin me. It might be I just have to keep playing with it until I haplessly stumble onto the right settings.lol Another thing is I'm having a hard time actually seeing the puddle, or where my wire is actually touching, like I really can't see the actual edges of the metal I'm trying to weld. I have #10 lens
    Are u the same person that was asking about the weld through primer awhile ago.
    If you are. That popping, balling up, splatter hard to weld. I've experienced some of that when you try to weld through that weld through primer.
    The only thing I can say is what the other guys are saying. Clean metal and a tight fit up.
    What machine are you using?
