Page 7 of 7 FirstFirst ... 234567
Results 61 to 66 of 66
  1. #61
    Nov 2003
    3,584
    Quote Originally Posted by ja baudin View Post
    If you use a push pull gun, your machine will be dedicated to aluminum only. To weld steel you will have to remove the push pull, switch drive rollers, and switch the spool of wire in the cabinet of the welder to steel. If you use a spool gun, your machine can weld both steel and aluminum. Example, pick up the spoolgun and weld aluminum or pick up the mig gun and weld steel. No switching anything. That may be a big factor for you to consider if this is your only machine and using if for both. It's called "gun on demand" capability. Ja
    It is true that it is a bit more trouble to switch to the push-pull...
    BUT in either case you will still need to change gasses and purge lines... even with "gun on demand"...
    the Alumapro push pull is only worthwhile if you are going to push a lot of aliuminum at a time... the 30A is great for small repairs.. where the 1 pound limit on spools is not a hinderence...
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
  2. #62
    Mar 2011
    La
    287
    Quote Originally Posted by H80N View Post
    Clarification: With gun on demand, if you have two bottles and two regulators on the back of the machine, you don't have to switch back and forth between separate gas cylinders. Just turn the one on you need. Not hating on you H8ON, just making sure the op gets a better idea on how the set up works.
    Dynasty 200 DX
    Millermatic 350P, XR-Aluma-Pro
    30A Spoolgun
    Lincoln Pro Mig 140
    Hypertherm Powermax 30
    14" Rage Evolution 360
    40 ton press brake
    Evenheat Kiln
    1x42 / 4x48 belt sander
  3. #63
    Nov 2003
    3,584
    Clarification: With gun on demand, if you have two bottles and two regulators on the back of the machine, you don't have to switch back and forth between separate gas cylinders. Just turn them off and on. Not hating on you H8ON, just making sure the op gets a better idea on how the set up works.
    No... clarity is a good thing...
    had not even thought about the two bottle rack... my MM350P has the single rack... guess I got a mental lock on that mindset..
    My Blue Stuff:
    Millermatic 200
  4. #64
    Mar 2011
    La
    287
    Yeh, mine was the same way. I fab'd an extension of the bottle rack and the cylinders piggy back each other instead of side by side. Thanks, Ja
    Dynasty 200 DX
    30A Spoolgun
    Lincoln Pro Mig 140
    40 ton press brake
    Evenheat Kiln
  5. #65
    Nov 2011
    159
    Ok I was asking because there is one on EBay (xr-30 version) push pull but I think for my occasional aluminum needs the 30A will suffice
  6. #66
    Default millermatic 211 or 212 or 252
    You can convert it to a spool gun by buying the canister
