Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 66
  1. #51
    Default millermatic 211 or 212 or 252
    Congratulations on your new investment. You will be very happy that you went with the 252. I have the 15' Bernard Q gun installed and couldn't be happier with the setup. .045 solid and .045 gas shielded flux are the only wires I run and the 252 just purrs at higher output settings. Enjoy and keep us posted on how it works for you. Don't forget if you ever set it up for aluminum to let us know how it does. I am dying to try AL work with it. Have fun.
  2. #52
    4,446
    It only cost twice as much to get the best in this case, If you are worried about duty cycle then it means materials and manpower, the difference in productivity and material savings could add up quick, even on some light gage the 250 class is twice the 211 and wire half the price for a big spool. Cuts the time and cost in half, could pay the juice on a project or 2?.
  3. #53
    Nov 2011
    159
    Texas113;
    Will hopefully have the 30A spoolmatic in a month or so as I have found a used one for $600 but it is an hour and a half away.
    Next time I have some business in that city I will email the seller a few days before and see if I can get it maybe even cheaper as it has been for sale now for 2 months at $800 and has not sold.
    We have agreed "tentatively" to $600 but I'm sure they will come down a little more.
    Ran a short bead "t joint" on steel last night using the settings in the front cover and all I can say is "wow"
    This is what I was missing out on with the smallish Lincoln SP170-T...power!
  4. #54
    Jun 2012
    Tracy, CA
    221
    I use both the 211 and 252. They both have their place. 211 for the field 252 for the shop. The one thing I never liked on the 211 was the Spoolmatic 100. I was doing a nice size aluminum job last month and this gun caused me more headache than it was worth. The gun broke in the middle of my job so I had to overnight a push pull gun to the shop. Big $$ but worth the time it saved.
    This is the bead I ran with the new XR AlumaPro.
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic 350P Aluminum
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    SuitCase® X-TREME™ 12VS
    Multimatic™ 200
    Millermatic® 211 Auto-Set™ w/MVP™ (Sold)
    XR-Aluma Pro Gun
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Victor Oxy/Acetylene Set
  5. #55
    Nov 2011
    159
    Kvwall;
    Nice bead!
    Can I expect similar results with the Spoolmatic 30A?
  6. #56
    Jun 2012
    Tracy, CA
    221
    Quote Originally Posted by ericher69 View Post
    Kvwall;
    Nice bead!
    Thanks. I'm not sure what to expect from the 30A. The AlumaPro is a push-pull gun. I hear a lot of good things about the spoolmatics. They just aren't made for production work. I'm sure you can get a nice bead if everything is setup properly and your technique is good.
    Miller Dynasty® 350
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    Multimatic™ 200
    XR-Aluma Pro Gun
    Diversion™ 180
  7. #57
    Mar 2011
    La
    284
    With a lot of practice, yes. My opinion, they weld the same. I personally like using the 30A more than the push pull. Good luck.
    Dynasty 200 DX
    Diversion 180 (sold)
    Millermatic 350P, XR-Aluma-Pro
    30A Spoolgun
    Lincoln Pro Mig 140
    Hypertherm Powermax 30
    14" Rage Evolution 360
    40 ton press brake
    Shop full of tools
  8. #58
    Nov 2011
    159
    Thanks for the info!
    Now can the spoolmatic 30A be converted to push-pull or visa versa?
  9. #59
    Nov 2003
    3,520
    There is a version of it called "XR-30" that is configured as a push pull..
    http://www.millerwelds.com/om/o1555e_mil.pdf
    But I would not think it to be a very cost effective conversion...
    at that point... I would keep the 30A configured as is and start looking for an "Alumapro"....
    that is the route I took..
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
  10. #60
    Mar 2011
    La
    284
    If you use a push pull gun, your machine will be dedicated to aluminum only. To weld steel you will have to remove the push pull, switch drive rollers, and switch the spool of wire in the cabinet of the welder to steel. If you use a spool gun, your machine can weld both steel and aluminum. Example, pick up the spoolgun and weld aluminum or pick up the mig gun and weld steel. No switching anything. That may be a big factor for you to consider if this is your only machine and using if for both. It's called "gun on demand" capability. Ja
    Dynasty 200 DX
    30A Spoolgun
    Lincoln Pro Mig 140
    40 ton press brake
    Shop full of tools
