Page 1 of 7 123456 ... LastLast
Results 1 to 10 of 66
    Nov 2011
    159
    Default millermatic 211 or 212 or 252
    I am looking at the 211 to do some light aluminum work, stainless and mostly mild steel.
    Question; is it worth the extra money to get the 212 (same specs except for increased duty cycle).
    Was looking at 252 but spool option is big increase in $$.
    Main uses are home fabrication for myself with small compact tractor implement work.
    I currently own a Lincoln sp170-T and a Canox sparkler AC/DC 225/150
    Was going to keep the stick but if 1 welder can replace the 2 I have I am open to that.
    Any and all positive opinions are welcome!
    Wa
    624
    Sounds like the 211 is your best bet if the aluminum capacity fits your needs, if not the 252. For home use I doubt the duty cycle will matter much to you.
    Jul 2010
    Four Flags city
    304
    If you can swing it go for the 252 with the 30A.
    You cannot use amps you did not buy and the 30A is(in my opinion)the gold standard in spool guns.
    May 2013
    East Tenn
    148
    The 211 suits my needs. Haven't overloaded the machine and if I need to weld thicker material than what my machine is rated I just make multiple passes. Ultimately you have to decide if you wanna pay the big bucks for a machine that you may never use the top end of it, being a home welder and All. Just my .2$.
    2,914
    Elaborate more on your light aluminum- Mig AL is really only good down to 16g
    SS- you'll need a Mix gas = $$
    A Tig machine might be a better option since you already have the SP170 T and the Stick machine to cover your Mild steel needs.
    Tig machine and a bottle of Argon will cover your Lite al and SS
    Illinois
    622
    Big dollar difference from211 to 252. For home hobby use I would definite say the 211. The dual voltage 110/220 may also be a worth while feature. It's a awesome machine and STILL IN REBATE PROGRAM.
    Once you have the 211 then save for a Miller 200/250 syncro. Now you'll have stick and tig. Then you can sell the others.
    Nov 2011
    159
    Quote Originally Posted by Precision View Post
    1/4-3/8 aluminum. Anything thicker and I could bevel with multiple passes (within reason)
    I really want the 252 but realistically only need the 211.
    I can use the stick for SS also (does a really good job from what I remember)
    The TIG option would be very nice (Dynasty DX200) not really into the Diversion models.
    Will the 211 be a marked improvement in capacity/ability (besides aluminum with sp100)?
    May 2013
    East Tenn
    148
    I agree 110% with BD1.
    Nov 2011
    159
    Thanks to all that replied.
    You have confirmed what I needed to hear that I only really need the 211 (even though that 252 would be saweet) but not for 3x the money!
    A TIG option may be something to look at in the future to replace the sparkler.
    How much could I get for the sp170-T? and for the Sparkler?
    Jan 2008
    328
    Default 3/8" al?
    The 211 will not get much penetration on 3/8" AL in a single pass weld. The 212 has a lot more top end (higher volts) then the 211. 15 foot gun also.
