Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
    Oct 2005
    North Central Indiana
    782
    Default Bought one of these today
    I have a large stack of 10 ga. sheets this shear will come in handy cutting up. It's a lot faster than setting up the plasma or torch, all I need is an extension cord and my straight edge...and plasma consumable will only continue go higher.
    I bought the last one they had.. good price .
    http://www.tools-plus.com/makita-js3...term=MAKJS3201
    Aug 2011
    14
    Never used a shear on 10-GA before, always used a nibbler.
    http://www.plumbersurplus.com/Prod/M...FcU5QgodtS8A9A
    Oct 2006
    Illinois
    643
    Looking forward to the results. The shear can go as tight as a 2'' radius. Never used either for that thickness.
    Oct 2005
    782
    I'll put some pictures of cuts up after I get it... I was debating between shear and nibbler, after considering what others that have used them said it seemed to me the shear fit my needs better.
    alabama
    752
    Curious as to how long the blade will last on 10 gauge. I have one for lighter gauge but never use it. I dont like the distortion it makes. Also have a Modern nibbler but dont use it either.
    2- XMT's 350 cc/cv
    1- BOBCAT 250
    1- TRAILBLAZER 302
    1- MILLER DVI
    1- PASSPORT PLUS
    1- DYNASTY 200 DX
    1- MAXSTAR 150 STL
    1- HF-251 BOX
    1- S-74d
    1- S-75DXA
    2- 12-RC SUITCASES
    1- 8-VS SUITCASE
    2- 30 A SPOOLGUNS
    Oct 2005
    782
    Quote Originally Posted by fabricator View Post
    I imagine speed and distortion has a lot to do with blade adjustment and the sharpness of the blades themselves. Pushing a dull tool could produce bad results.
    I use a product by Walter on all my cutting edges, the stuff really makes a difference in the quality of a cut, life of a cutting edge and the performance of a tool. I'll be using it on the shears too.
    http://www.walter.com/Walter/en-us/m...icants/coolcut
    Jul 2010
    385
    What's the difference between that and the Makita JS3200? I recently bought a 3200 and like it.
    northern NJ
    1,915
    I can't imagine that being faster than a plasma unless you have it stored away. For me I just flip the switch & turn on the air. I too am curious as to the edge quality on 10 gauge.
    MM250
    RCCS-14
    Oct 2005
    782
    Quote Originally Posted by Helios View Post
    Probably not that much difference, especially if you like the way your's cuts. The product probably just needed a face lift to keep up with it's competition in the market place.
    Glad you said you like yours. I have faith in the Makita brand.... if they say it was built to cut 10 ga I would assume the tool making nice clean cuts was on top of their list of things for the tool to accompolish.
    Just like hacking with a to expensive to run plasma machine that sits in the corner... I use O/A and a tip cleaner mostly, they can stick their high price plasma consumables where the sun don't shine....metal doesn't know or care if it's cut by a saw, plasma or O/A outfit. or a Makita shears ...
    Dec 2011
    435
    Quote Originally Posted by tackit View Post
    Tackit,
    Now you've peaked my interest. I've been considering a plasma cutter and it would be nice to hear the opposing viewpoint. Everyone I've talked to either owns one or sells them. They have all said they are the "greatest thing since sliced bread". But one has to realise that salesmen and those that have invested in something may be reluctant to diss it. What kind do you have and what has been your experience? I currently use a vertical band saw(Doall) power hacksaw, O/A torch,chop saw or strand mounted manual shear for cutting.---Meltedmetal
    ps forgot about arcair, haven't used it in a while.
