Results 1 to 10 of 14
    Feb 2011
    GRAIN VALLEY,MO
    8
    Default Syncrowave 250 problems
    I am having trouble wiith a Syncrowave 250...when I ease off the pedal to slowly back out of aluminum welding the arc just stops..I thought it might be the pedal so I bought another and that did not help.
    Jul 2010
    379
    Are you saying you have no throttle? In other words, is the pedal acting like a momentary switch, where it's either ON or OFF, but there's no difference in the amperage between half-pedal and floored?
    If so, check your panel. For aluminum welding, you should have:
    - AC Polarity
    - Process: TIG
    - Amperage: Remote
    - Output: Remote
    - Start Mode: HF Cont.
    Have you checked/gapped the HF points?
    Feb 2011
    GRAIN VALLEY,MO
    8
    Quote Originally Posted by Helios View Post
    - AC Polarity
    - Process: TIG
    - Amperage: Remote
    - Output: Remote
    You are correct, it is just off and on and no difference between half pedal and floored. all of the settings are correct. I have not checked the gap..what should it be?
    Jul 2010
    379
    I'm no tech by a long shot, but it sounds like your OUTPUT control isn't functioning properly for whatever reason.
    I believe point gap should be .008" (and I think, based on the manual for my 330A/BP, that a larger spark gap will cause you to have a more aggressive/effective HF arc starting) but my gut says the points ain't your problem. Can't hurt to check, though, I guess.
    Maybe Cruizer or somebody else who knows what they're talking about (not me) will be along here soon...
    Feb 2011
    GRAIN VALLEY,MO
    8
    Thank you Helios.
    8,172
    Need a little more info, and the serial# Does the pedal control the arc at all? Are you in remote for contactor control and weld control. do you have a torch water cooler.
    Jul 2007
    9
    Sounds just like mine. Are you saying the pedal works as an on off switch for contactor control, but does not adjust current at all, ie if the panel is at 100, you can have 0 or 100. If the panel is at 111 you can have 111 or 0 ? ( nothing in between?)
    Feb 2011
    GRAIN VALLEY,MO
    8
    Cruzier, I changed the pedal and that solved my problem..Thank you guys for your help!!!
    Jul 2010
    379
    Quote Originally Posted by smoking1320 View Post
    Huh?
    8,172
    HUH, you said you changed the pedal. did you not plug it in?????? WTF
