Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    turbo38t Guest
    Sure.....lock out my lsathe, grinder, wire wheel etc when I'm using them ;P
    Quote Originally Posted by Daniel View Post
    Usually on dangerous equipment you lock it out. You guys must have a lock out procedure right?
  2. #22
    Default That's real tough talk.
    Quote Originally Posted by Paul S:309057
    All as well work for KSI belridge Aera We still have our shirts out ! Because we stand together as welders and fight this !
    The welders to the south of us Need to sack up! Instead of Caving in !!!
    maybe you can help teach your hand his craft and you wont have to tuck it!
  3. #23
    Mar 2011
    3
    yes, or shut down. When in the area of these type machines any loose clothing is a problem. On 24/7 process equipment sometimes you have to walk thru and in between to work while it is still running.
  4. #24
    Sep 2009
    South Carolina
    570
    Reminds me of the cotton mill days. had to turn sideways to squeeze through the machines all shift long. if you messed up, you got knocked in the floor.
    late 90's a lady got her scalp ripped off her head. so many got pulled into the machines.
    one hot lady, I do mean HOT, got her shirt caught in a take up roller. it was slowly ripping it off and she was in the middle and couldn't reach the stop.
    I just happened by and shut off the loom. the guys about whipped my azz for that.
    I wish the whole freaking country could stand together to make a statement like you guys are doing.
