Results 1 to 3 of 3
    Sep 2012
    26
    Default if the polarity in your welder/generator is in reverse
    if polarity is in reverse then someone messed with your machine,by reversing the two wires that go to the solinoid near your throttle.
    Dec 2012
    Simcoe Ontario
    91
    You switch polarity by switching your ground and lead
    Oct 2004
    Edmonton, Alberta
    8,012
    Pretty simpe really, I assume its a SA200, basically someone flashed the fields in the wrong direction, so just reflash in the correct direction. No big deal....
