    Default 250 gallon reverse smoker
    Well I always wanted one so here we go.......
    Oct 2011
    Montana
    54
    I assume you are putting water in with the hose. See that foam in the Tank7 photo? That is from the water reacting with the mercaptan (the odiferant, aka stinky stuff, used in propane). From the MSDS for mercaptan:
    PHYSICAL HAZARDS: Extremely flammable liquid and vapor. Vapor may cause flash fire. Contact with water or moist air may generate flammable and/or toxic gases.
    Be careful.
    Quote Originally Posted by pin2hot View Post
    I assume you are putting water in with the hose. See that foam in the Tank7 photo? That is from the water reacting with the mercaptan (the odiferant, aka stinky stuff, used in propane). From the MSDS for mercaptan: Be careful.
    note taken......
    Oct 2011
    Montana
    54
    Looking good!
    Glad things worked out. What I shared earlier was 'the voice of experience.' I guess I was lucky.
