Results 1 to 8 of 8
Hybrid View
    Oct 2005
    North Central Indiana
    782
    Default I need help finding weather proof fan speed controls
    I have been searching for weather proof fan speed controls but can't find any, anyone have info on them or know if such a product exists, thanks.
    Here's the fan with amps and watts info I bought for the forge I want to control. I don't believe it's brushless.
    Leviton makes inside the house fan speed controls I might have to make do with but I would prefer weather proof, unfortunately they don't make a weather proof box for their fan speed control switches.
    http://www.ebay.com/itm/Squirrel-Cag...0021821%26trol
    May 2013
    East Tenn
    148
    Maybe check out a greenhouse supply company. Dunno who but that's a decent startin point. Hope it helps tack.
    Oct 2007
    Cave Creek Az
    1,036
    You don't need a speed control with the shaded pole fan. Just make a shutter that covers the intake, then adjust it to whatever you like. A lot of them will come with a shutter on them.
    Oct 2005
    782
    Quote Originally Posted by walker View Post
    I was thinking about that but worried about burning the motor up. But I think that's the safest way to go if I can't find a weather proof speed control. Thanks walker for your input.
    Jul 2010
    378
    I bought a fan a lot like that for a coal forge I made, and I jacked around looking for ways to control the motor speed (you can't on the fan I have, wrong kind of motor, it will apparently mess up the motor if you put a speed control on it) but here's an easy, 10-minute fix to regulate the airflow:
    Cut a round piece of sheet metal that's about the same diameter as the intake for the fan. Weld or braze the round piece of sheet metal (I used the lid of a mayonnaise jar) to another rectangular piece of sheet metal, so that the round piece and the rectangular piece look roughly like a lollipop.
    Drill a hole through the "handle" of the "lollipop" and drive a sheet metal screw through the "lollipop" into the housing of the fan. The "lollipop" needs to pivot on this screw. Now if you turn on the fan, and you pivot your "lollipop" intake cover so that it completely/partially/doesn't cover the round intake for the fan, you can go from about 15% of the fan's output to a full 100% ... and you don't have to jack around with speed controls or worry about messing up your fan motor. Plus it''s free and it works like a charm.
    Now, with the money you would have spent on the speed control, go and get yourself a foot-operated switch to turn the fan on and off:
    http://www.harborfreight.com/power-m...tch-96618.html
    Oh as for the "weather proof" issue, I rigged my fan with a quick-connect/disconnect setup, so that I can quickly attach or detach the fan. Basically, the fan just "hooks onto" the pipe that goes to the tuyere of the forge...slide it into the slots to attach the fan, lift and tilt to take it back off. That way, I can keep the electric fan indoors when I'm not using the forge. It works great. Real easy and fast.
    Oct 2005
    782
    Good Ideas Helios. Thanks.
    Somewhat off topic but I was wondering if anyone has built a good home aluminum foundry. I have wanted to build one for quite some time and hadn't thought to ask around here.
