Results 1 to 10 of 13
    Default aluminum welding table HEAVY DUTY
    Hi, I started making a table out of 2"x6"x1/8" box aluminum. Im not sure what I should use as a top. What would a table like this be worth? And how can I make it as functional as possible? Thanks. Pics below.
    alabama
    754
    Well, that would depend on its purpose.
    2- XMT's 350 cc/cv
    1- BOBCAT 250
    1- TRAILBLAZER 302
    1- MILLER DVI
    1- PASSPORT PLUS
    1- DYNASTY 200 DX
    1- MAXSTAR 150 STL
    1- HF-251 BOX
    1- S-74d
    1- S-75DXA
    2- 12-RC SUITCASES
    1- 8-VS SUITCASE
    2- 30 A SPOOLGUNS
    Quote Originally Posted by fabricator View Post
    well thats what i need advice with. I am a welder, but never saw a all aluminum welding table. If I should throw 1/2" aluminum plate on top let me know........what would you do with this table?
    East Tennessee
    143
    Use a steel top... Spatter will kill you if you use aluminum.
    Professional Auto Mechanic since 1974
    My own shop since 1981
    Cya Frank
    Quote Originally Posted by Frank865 View Post
    really? i see what your saying, but it seems such a shame to throw steel on top of this alum table.
    May 2013
    East Tenn
    148
    Cover it with steel and comeback with a flapper disc and polish the crap outta it. Frank is right,splatter will ruin it and really break your heart.
    Raymore Missouri
    1,925
    personally, I would have never wasted that aluminum on legs for a welding table.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    1,919
    An aluminum table top would be good for small tig work or assembly work that needs to be handled carefully. Aluminum is soft so it would not mar/scratch the pcs. as easily. As far as a normal welding table I don't think it would have much use. To soft, will gouge easily, unable to tack pcs./fixtures to easily, expands/contracts at a different rate than steel.
    #1) top material -- If used for general welding use a steel top.
    #2) worth? -- As a welding table not much imo. Used welding tables don't command much money.
    #3) functional -- Maybe polish it & put a nice wood top on it to use as a desk?
    Yeah we had the material laying around. Still not sure what to do with it.....hmmmmm.
    Anymore ideas? Like I said if you had this table what would you do with it?
    May 2013
    East Tenn
    148
    If it were mine I would finish it out in alum and put my ole Tombstone on it with lead hangers and maybe a bench grinder or vise on it. Lots of crap hangers and a shelf or two for more crap.
