Results 1 to 2 of 2
    Unhappy white face millermatic 35 wont arc!!
    I bought this machine a few months ago and just got it powered up went an got gas and thought I was ready to play..... i was wrong. It has spoolmatic one conversion kit setup for aluminium and worked great when i bought it. I took the cover of and the relay clicks but does not pull the contactor together when i push the contactor together the spool gun arcs. the spool gun feeds wire and gas just no arc any information would be much apreciated.
    sincerely the newb..
    Aug 2008
    Orange, TX
    1,226
    So you'll need to determine if the relay contacts are bad or the contactor coil is bad.
    Unit SN?
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
Tags for this Thread
