Results 11 to 12 of 12
Thread: popping?
    Cave Creek Az
    1,055
    My TB was welding crappy a wile back, turns out I had a poor cable connection. Swap cable from one of the good welders to check. I have had it weld poorly on other occasions because my son would play in the back of the truck and flipped the switches, or move the cables from CC to CV. Take a pic of the front panel as it is set up to weld and post it. Also, if there is a remote on there disconnect it and try.
    Jan 2013
    15
    Default popping?
    Hey thanks everyone for the replies. It turns out it was a mixture of things. Weak ground clamp helped a bit but I pulls the cover off and it turned out the guy had the wireless remote box wired up wrong.
